Evinrude 25 hp type nrs
Turin
I own a Evinrude 25 hp engine with the type nrs 07218 255b62b
I need some spare parts fuel pump some nuts and bolts (In Holland the standard bolts and nuts are from a different type, so the type used on the engine will cost a few euro's a piece)
pull starter parts and so on.
I can now buy a broken Evinrude 25 hp engine with the type nrs be25balcos 6016709
My question is, are the most or some parts from this engine usable in mine??
The engine is going to be really cheep.:D so it doesn't have to be completely compatible. Fuel pump is the most Important because the one on my engine doesn't do anything :(
Daviet
Re: Evinrude 25 hp type nrs
I can't cross any of the numbers you listed.
I guess if the motors look the same, some parts might cross from one to the other.
Vic.S
255B62 is a 1975 model
BE25BALCOS is a 1985 model
Both Belgium made I think
the Parts catalog
should enable you to compare parts numbers. But you wont find your specific model numbers listed in the American catalog.
If part numbers are the same for the two models you may be in luck. If different they probably wont fit.
Ordinary fuel pumps are pretty much interchangeable. you'd be very unlucky to be unlucky there
