Evinrude 25 hp slip/gear issue with video
IcedEye
I recently had an issue come up with my 1996 Evinrude 25 hp 2 cylinder . This began last year and would occur randomly while at WOT but would only "miss" one time and then keep moving just fine. I've been looking at changing props so picked up a tach to see where I currently am with rpm which is 5100 with 13 pitch. As of 2 days ago the "miss" got so bad that I let off on the throttle before getting to WOT, today I saw that it began around 4200rpm with an 11 pitch prop. I was hoping it was just hub slip and already ordered the new prop. This did not fix it.
So I am hoping someone will recognize the issue from my video and description.
From searching here and other sites I've seen the clutch dog or forward gear could be my issue as well.
Link to video if above does not work:
https://www.youtube.com/watch?v=rPpd9FIBQdI
IcedEye
Summary of what I've found:
Originally ran with 13 pitch prop and issue began last year very minimally. 2 days ago it became bad enough that WOT cannot be reached.
Changed to brand new 11 pitch and nothing changed.
Occurs around or nearing peak rpms. WOT rpms for this motor are 4500-5500.
All runs have been in a straight line on calm water
Honorary Supreme Mariner
Could not see the video.-----But I would be taking a look at the clutch dog and forward gear.------If it has in fact been jumping out of gear you may need some pricey parts.-----When you take it apart check and see if the BOTTOM shift rod is in fact fully screwed into the lower unit.
IcedEye
Thank you, I will hopefully have it apart tomorrow. I've added another link to the first post directly to YouTube
flyingscott
That looks and sounds more like an ignition miss. Are the spark plug wires on tight? Check all the electrical connections and look at the wires where they come out of the stator.
frobotz
I agree, this sounds like ignition. momentary studder in the timing.
jimmbo
The first miss/jump sounded like what clutch dog would sound like, but the rapid fire of the repeat misses, makes me also think it's something else
F_R
Same here. At first I would have said clutch dog, but toward the end I changed my mind. Sounds like ignition. Maybe as simple as a spark plug arcing out.
oldboat1
Might try it without the hood, in case the hood fit or latch is a factor, maybe after some work was done.
IcedEye
Alright I've gone over every wire I can see and there are no exposed wires that I can find. Inside the spark plug wire from the coil it looked like there may have been a little rust/corrosion, cleaned everything up. Will run it in the morning if weather allows.
IcedEye
No luck yet. Brought a new ignition coil as well and swapped it between both. Same symptoms
F_R
My first bet would be a spark plug. Hey, they are cheaper than a power pack or that coil that you bought.
IcedEye
I'll try another set of plugs. I do change plugs each year and the last set had the same miss but never the multiple at the same time.
The new plugs have approx. 20-25 hours on them and did the same single miss at wot only occasionally up until the other day. They are at book recommended gap as well.
oldboat1
The book gap recommendation changed from .040 to .030 at a point in the past ('80s I think, but not sure). If at .040, you might want to try the narrower gap.
Testing is the path forward.----Run with a timing light hooked to # 1 and observe the light.----Repeat the test with # 2 cylinder.
IcedEye
Just an update. Ran it today finally with the timing light and losing spark on both cylinders. Will be looking to test the power pack and getting another if needed. I'll update with results from that when its completed and hopefully help someone else in the future.
IcedEye
Replaced the Power Pak today and it is back up and running strong.
