Evinrude 25 HP, 1983 Ignition woes....
HughN
Woe is me!<br /><br />The ignition cut out on me today and left me stranded. No sparks, no nufink.<br /><br />Does anyone know what resistance the stator and trigger coils should be on a 1983 25HP E/S Evinrude please?<br /><br />I don't suppose there is any easy way to test the ignition module? It's potted with resin tht is just transparent enough for you to just KNOW that it'll be real expensive!<br /><br />Cheers...
alcan
Re: Evinrude 25 HP, 1983 Ignition woes....
Hi Hugh<br />Before you get too exited, test the kill circut. Check for broken/loose wires also remove and clean grounds.
