Evinrude 20hp help
Ashleybsoton
Some advise would be great with this engine, It's a evinrude 20hp not sure on year as there's nothing on it to tell me but I got it cheap and took a gamble, I cleaned the carb through and got it to start, and idle lovely, but did notice that the gear linkage cover plate was missing so got one and soon as I fitted it the water stated to bubble up at the bottom of the leg and just cut out the, then soon as you remove it the engine runs fine again? And the other issue with it is as soon as you select forward throttle it and hold it there it develops a misfire as such, any help would be appreciated thanks
F_R
Honorary Supreme Mariner
Lets start over. Are you running this thing on a boat on the lake, or are you running it in a bucket?
Crosbyman
have you inspected the lower housing for any exhaust restrictions below the linkage cover plate ?
Ashleybsoton
Yeah I removed the leg and can't see anything that would be blocking the exhaust but for some reason soon as the linkage cover is put on it runs then all of a sudden the water bubbles up at the bottom of the leg and it stops
F_R
Well, the exhaust is supposed to exit the outlet aft of the propeller. Why it is making the motor stop is a mystery. Except it is no mystery that the back pressure on the exhaust increases when you force it out underwater. That making it quit could indicate a very sick powerhead, but I doubt it. It could also mean that you merely have to give it some more throttle if this (the quitting) is only happening at slow idle speed. It could also be happening if there is an exhaust leak under the hood and it only happens (the quitting) if the hood is on.
Crosbyman
Well I guess you need a wire mesh on the linkage inspection port ! it will keep the crud out at least and the engine will run:flame:
w2much
As FR mentioned. Run it with the cowl off. You may be sucking exhaust fumes back into the carb.
