Tim Frank
- Jul 29, 2008
- 5,346
I am replacing the impeller and when I removed the L/U the drive-shaft stuck in the powerhead and the lower end came out of the gearcase.
I have removed the shaft now and cleaned up the upper end.
Should I be able to just replace he shaft in the lower unit or are the seals going to be compromised?
Obviously I would rather not open up the gearcase if I don't have to.
The manual is unclear but the gearcase at this point has no issues and is watertight....or at least it was.....:facepalm:
