I have a Evinrude 1977 55hp, it is really hard to cold start; it doesn't even sound like it kicking. I've tried a couple of dfferent starting procedures, <br />Procedure A...<br />Fast idle up<br />Key in to choke <br />turn key till it kicks<br />let go of key<br /><br />Procedure B....<br />No fast idle, but choke<br /><br />Procedure C.... only one seems to work<br />No fast idle, no choke<br />crank until it fires or battery goes flat (giving starter chance to cool every 5 secs)<br />Once kicks quick staps at choke, and go for a bit of fast idle.<br /><br />I find often if you leave it for 10mins then try again you may get a kick.<br /><br />The engine will then run without a miss all day, and restarting after 5min or 4 hours is always first touch of key. Up till 2 days its good for starts.<br /><br />I have used carby cleaner sprayed into both carbs, <br />New spark plugs, <br />Decarbed the engine, <br />Tried higher/lower octane fuel, <br />Battery is holding 12.65v, cranking at 10.8v
