Chuck Whittern
- Jun 9, 2001
- 1
My 1967 Evinrude 60 hp v-4 has been running like a champ, but last time out we stopped to try fishing in one more spot. Engine started, sputtered and coughed and would not fire again at all. Switching tanks and attempting to start with primer bulb squeezed did not help - no firing at all. Poured a little gas into carbs - nothing... <br /><br />Engine has new dist. cap, rotor, plug wires, plugs, gas hoses, and was running fine. <br /><br />I have checked the safety switch - OK. <br /><br />Checked all wiring and connections - seem OK <br /><br />Checked point gaps - Set to .020 as per manual. <br /><br />Spark tester shows no spark at all... <br /><br />This engine has a magneto (no external coil), even though my 67 Evinrude Service Manual shows a coil and distributor in its pictures. <br /><br />Is there some way to test the magneto? <br /><br />Any ideas what this could be??? <br /><br />Thanks in advance! <br /><br />Sincerely, <br /><br />Chuck Whittern <br />Hudson MI <br /><br />cwhittern@dmci.net
