evinrude 140hp oil injection problem
gazza2007au
hi guys i just brought a boat it has a evinrude 140hp on it i would guess the motor is early 80's the owner said that theres to much oil pressure so when the engine is cold it will blow a little smoke nothing to much but noticeable its nothing like a current 4 stroke ;) he said the smoke goes away after 5mins of running the motor and after the motor is turned off a little oil leaks from the prop/exhaust does anyone know what could be going on? the oil container i was told is under the floor
all help appreciated guys
JoLin
Re: evinrude 140hp oil injection problem
Compression test the motor.
There's no such thing as "oil pressure" in a 2-stroke engine. The seller is either ignorant or pulling your chain. I think a little smoking at cold start is normal, but if there's a lot and it goes on for awhile it's because unburned gas/oil mix is being pushed past the (worn) piston rings. That would also explain the unburned mix dripping out the exhaust after you stop the motor.
reeldutch
smoke during a cold startup for these motors is normal.
when they warm up it should be less.
if its exessive you might have a leaking vro pump.
check the spark plugs and tell us how they look like
the best way to eliminate oiling problems wich could lead to major engine problems is to mix the oil yourself.
i know lot of people like the Vro system but on an older motor you have 3 options:
-1 relaying on your 30 year old oil injection pump.
-2 replacing it with a brand new pump
-3 disconnecting the oil warning system capping of the oil inlet in the pump, and using it as a straight fuel pump mixing 50:1 yourself.
in my opinion # 3 is most secure and cheapest way to do it.
tashasdaddy
Evinrude 140 WHAT???? model, year,
gazza2007au
thanks so much :) i will get the oil system blocked off i will call my local boat shop today and see if they can do it the engine model number is AE140TLESE wow i dont a search last night and the engine is coming back as 1990 model can someone please confirm this?
i will check the plugs now
gazza2007au
checked the plugs there dark brown (not black) and wet
mhg
at shopevinrude.com you can look up engines by the year
you will find your model # under the 1990 year
gazza2007au
thanks mate that really helped i can confirm my engine is a 1990 model yippee now i just have to get it fixed
