Re: evinrude 140 blown again
water pump OMC, spark plugs champion L77 jc4,oil TCW3,fuel grade reformulated 89 octane,RPM's 5000 @ WOT, wrist pin snap rings are not true arch snap rings, motor has about less than 100 hours since last build, there is no other cylinder damage other than wrist pin. Was operating at 3800 RPM when it dropped the snap ring under perfect weather conditions. Engine was running cool with ample water supply. The boat is 17.5 ft bass boat, two people in the boat, not over loaded. Any more questions, please reply. I will try to answer them. Thanks!
