I have an Evinrude 135 HP v4 (135489-b) and I have recenly replaced (in this order) : the rectifier, stator, and power pack. <br />The rectifier shorted and blew the power pack.. So I replaced them and now I have an intermittent spark problem on #1 cylinder and only on the #1 cylinder. <br />When the engine runs at low RPM's (below 3,000) I get no spark at all using a timing light or I may get an extremely weak spark that is 180 degrees out.. <br />A week ago it ran fine and had good enough spark to set the top end timing with.<br /><br />Could this be a new power pack gone bad? And if so what could have caused the power pack to go besides a bad rectifier which obviously wasn't the case...<br /><br />Thanks for your help.
