Evinrude 130
Mspivey18
I’ve got a 1995 evinrude 130 replaced
plugs and plug wires
trigger sensor/
fuel hose
Carbs cleaned x3
fuel pump
fuel filter
Runs fine on muffs put in water it just Boggs down any help greatly appreciated
Mspivey18
trigger sensor/
fuel hose
Carbs cleaned x3
fuel pump
fuel filter
Forgot to Mention sometimes it will run great from place to place then whatever it is will happen and it will just keep bogging sometimes if I hit the choke it will get up and go like it should
The electric primer valve puts fuel directly into the intake air.-----This fuel bypasses the carburetor metering circuits.-----This points to a fueling issue.-----Checked for warped carburetor bowls ?----Water in the fuel ?
Mspivey18
They don’t seem to be warped to me, i only run 100% pure gas now I’m not saying that it don’t have water in it it could but we have drained the take 2 times it’s just weird how sometimes it will run sometimes it won’t. I definitely think it is a fuel issue I’ve just about ran out of options to check
You can not bring it over.----So post the compression test values.----Can be an important clue.
Post #1 mentions ---" fuel pump " -----Can you elaborate on that.----It means nothing to me as stated.----And does spark jump a gap of 3/8" on each lead using a test device.
Mspivey18
Have not checked the spark jump yet will do that next, on post 1 that’s a list of everything that’s been replaced, it had vro on it converted to just a regular Johnson/ evinrude fuel pump
Pulse limiter removed ?----That pump might be marginal to provide enough fuel.----So have your assistant operate the manual pump and test run.-----And perhaps test run with a portable tank mixed at 50:1.----Motors all run fine on muffs.----Even in gear on the trailer is still neutral, as prop does no work spinning in air !
Mspivey18
Have not done anything to pulse limiter so do you think that pump will be strong enough?
I usually do not assume and think.----I do some simple testing.----But I can not see , hear or touch your motor !!
saltchuckmatt
Why’s that?
Because your motor will run better at lower speeds and pollute less. It's a win, win, win.....motor likes it, mother nature likes it and your pocket book likes it.
Reliable pump, backed up with alarms ( must understand the alarm system and always make sure it's working ) and is easy, cheap price to repair.
Definitely time tested.
