Bdoyle0075
- Sep 7, 2010
- 19
Hello all. I am having a few small problems. I have an Evinrude 130 Hp. Problem one is: when at full throttle the motor dies down, bring it back to 2/3 throttle and it picks back up. I have changed all the fuel lines put a new water separator on and rebuilt the carburetors. I have noticed that the primer ball goes slack when this happens and once I pump it tight it stays at full throttle.
Second Problem is the motor smokes a lot and I mean a lot. I have notice a black sludge coming from the propeller and thought it might have been the lower unit leaking, but after checking it, it was still full. So I can only assume it is excess oil, making me guess that the VRO is miss feeding. Could there be an air leak in the oil line making it feed too much oil and could that be the full throttle problem?
Thank you any help would be appreciated.
Brian
Brian
