evinrude 130 1997
broke
i have owned boat for 3 yrs. it will not take off half the time,will act like it runs out of gas.one repair shop overhauled carb,one repair shop overhauled carbs and put more new plugs in it and last shop put new fuel pump and more plugs,still same problem. all shops say compression good,timing good advance good.also the engine has always felt like it has a miss to it at idle,if you get it going it runs fine except when you come down to idle and go to take off. it has a hard jump in the idle like a dead cylinder at idle./have checked compression 8-12-02 and top 2 cylinders have 145 bottom two have 135. have taken carb and plates off and looked at plates and all appears normal. help anyone :(
Dhadley
Re: evinrude 130 1997
OK. First we have to determine if we really do have a miss at idle. Use a timing light and go over each plug wire when the motor is "missing". The light should be steady on all. You will "see" the light blink concurrent with the miss. This will tell us if the spark is there at all times. You may have it when checking at cranking speed but not have it at, say, 1000 or 1100 RPM. <br /><br />What spark plugs are you using? What fuel? How old is the fuel? What oil? What ratio? Please be specific with your answers.<br /><br />Let us know!
