flathead6990
- Jul 19, 2010
- 29
Hello I have an evinrude 115hp. I was out on lake Friday night & was running at WOT & heard a buzzing noise and my temp sensor was going off in my control box. I have had this boat & motor for 8 years with no overheating problem. The temp gaduage needle did always run to the end of green to the little white line before the red/overheating mark. I Stopped the motor right when I noticed the alarm was going off. I Ran it for like 10 minutes the next day WOT 5300RPM & it started overheating again (I killed it before temp alarm).. Today I started it on muffs in my driveway & it didnt overheat??? Cant put it in gear on muffs so pulled start lever to increase the idle to like 4500rpm for like 5-10 min & it didnt seem to overheat.. I pulled the water hoses & water was coming out evenly on each side (v4 cyl)??? Please Help why would my motor have overheated??? What else can I check or do?? & this year motor has no tell tale.. Thanks in advance for any responses!! ;-)
