Re: evinrude 115 v-4 crossflow fires and dies
I will try this again....just fixed a guy's exact same problem....
Pull a carb, remove the bowl, and note the brass tube sticking down from the upper carb body.
Blow and suck on this tube to verify that it is open. If not, run small wire, welding tip cleaners, and carb cleaner to get those tubes clean.
Those tubes are the sole supply of gas to the idle circuits.
Fixed the other guy right up....all four of his were clogged after sitting 4 yrs.
Post back results.
