Evinrude 115 SPL Runs Fine Then Bogs Down And Dies
ballender817
I have a 1998 Evinrude 115 SPL on a Wellcraft 190 CCF that will start right up, idle all day long and run at idle speed but will only plane out for about 10-20 seconds then fall on its face. After pumping the ball on fuel line it will jump right back up on plane only to repeat the issue over and over. The ball feels a bit strange like its not springing "back into shape" very quickly. It does not leak and does not seem or feel old or dried out. Just looking for ideas at this point, motor has been running great until now. I am not suspecting bad fuel issue because it will power right up on plane just won't stay there long.
TIA
jakedaawg
Sounds like a fuel restriction before the bulb. Probably easiest to throw a $15 bulb at it first. If it's a built in tank you can remove the anti-siphon valve and fuel pick up to make sure it's all good.
emdsapmgr
Your test with squeezing the primer bulb is a good one. That action actually forces extra fuel into the carbs. The fact that the rpms pickup indicates that the engine was running lean (starving for fuel). One final test. Next time out, have a buddy constantly prime the fuel hose bulb. If the engine runs normally as long as you constantly prime the fuel hose bulb, they you have a fuel restriction. Could be a bad hose, anti-siphon valve, even a weak fuel pump. Make sure the arrow on the bulb points in the direction of fuel flow. Also, on the older hose bulbs, the ball valves do go bad. When they go bad, they don't like to support fuel flow going downhill. Make sure the fuel hose bulb is pointing in a generally "upward" position. If the hose bulb is laying downhill in the splashwell of the boat (or under the deck), you can have fuel flow problems.
Honorary Supreme Mariner
Test run with a " known to be good " hose and portable tank.
James R
You can mix a jug of fuel and stick the end of the hose in it. If the motor runs ok you have a restriction , probably at the pick up. Maybe the breather vent is blocked. Try the vent first.
ballender817
Thanks for the advice, I will look into the fuel delivery issues mentioned above!
