rainman99
- Apr 13, 2009
- 207
Hi I'm a newbie and this is my first post.(Great Forum ) I just bought a 1973 Well craft air slot 165 with a 1973 Evinrude Starflite 115 HP motor . I got it started it seem to run well but has a miss. Haven't had a chance to work on it yet weather has been bad. So I'm putting together a check list of things to do. I was hoping to get some help with and if you could add anything to it would be greatly appreciate.
6 gal. of new regular gas with TCW3 oil 50-1
New Battery What Size CC Amps ?
4 New Spark Plugs Champion L77JA What is the GapSize ?
Check Compression What is the PSI ?
Clean Intakes Shop Vac ?
DeCarb Sea Foam Mix ?
Check Timing What Mark ?
Check Water Pump Put hose in 5 gal bucket and see how it take to empty it and look at flow from outlets &feel heads ?
Change Gear Case Oil TC3 Were is drain Plug?
Grease all fittings and linkage What type grease?
Check all electrical connections Clean and Thighten
Check Tightness Of all acessable screws,nuts,bolts
Adjust idle RPM ?
This is all I could think of for now . Could someone please answer my ? marks it would save me the time of waiting for repair book. I'm trying to make sure I do PM Maintenance before it hits the water. Want to limit any surprises.
Thanks for any help you can give.
Rainman99
Adjust idle RPM ?
Rainman99
