Re: Evinrude 115 HP 1991 Fasttrack
Thanks t.h.<br /><br />By the way - the T&T motor cover is rusty as this motor has been operated in salt water - manual says to remove unit before removing motor. Do you know if it is possible to remove just the motor and sand, prime and paint it, to stop the corrosion. Do you know what the compression is on yours - on mine 3 cyls have 122 and the fourth 132 - i have not ran it in water yet.
