Bryant Davis
- Jan 8, 2002
- 24
Hello. I have a 1986 115 Evinrude that I need suggestions on. I had the motor completely rebuilt at the end of last summer (New powerhead, carb kits, etc.) and it has run super ever since. I fished all day Saturday in the Bay and it ran perfect. Unloaded it from the trailer this morning and it fired off as normal. Took off across the bay, got about 3 miles out and slowed to idle to adjust GPS. When I went to idle speed the motor died. I tried to restart and it sounded like it wasn't even getting fire. I pulled the hood to check for obvious probs and nothing. After sitting about 10 minutes I tried again and it was trying to start but would never catch. I would play with the warm up lever / choke and could get it to start but would not stay running. When it would fire off, it smoked heavily and sounded rough. (all the signs of being flooded). Finally had to get towed in.<br /><br />Here's what I checked:<br />1. Primer bulb was firm. Tried pumping bulb while cranking. No luck.<br />2. Took center bolt off fuel pump to check screen and pumped bulb, fuel squirted out.<br />3. Took lower screws out of carbs and drained fuel. Reconnected fuel line, pumped bulb and motor would start, run about a minute or two and flood out (or die..whatever it's doing) again.<br />4. Disconnected choke thinking it may be stuck.<br />5. Disconnected and blocked choke fuel supply line thinking fuel may still be passing through choke.<br />6. Verified spark.<br />7. Took fuel pump completely apart to check for trash. Screen / diaghphram were both clean.<br />8. Water line was squirting water both when it would crank, and while starter was turning. I'm pretty certain motor didn't overheat.<br /><br />To me, it acts like it's flooding out. Any ideas why it would suddenly start this, and what might be the prob? In addition, I don't know if this is coincedence or not, but this morning when I first started the engine on the trailer, the warning horn sounded on and off for about a minute. (This is with a cold engine) It would also chirp while attempting to start and it's never done that either.<br /><br />Thanks in advance for any and all help!<br />Bryant
