1997StingRay190
- Jan 1, 2009
- 57
Previous post's would let you know I bought boat (1997 Merc4.3 and Alpha 1 Gen 2) with a cracked block.
I got the old engine out and the new engine on Saturday. While the outdrive was off I saw I need a new yoke, joints, gimball bearing, 3 bellows, shift shaft seals, carrier assembly, anodes, and I think thats it.
What am I missing here? I want to do this once... the right way!
I have the engine out, the outdrive apart, the interior and carpet out - basically trying to go through the whole thing and make it right so I dont have to F with it at all this summer (except oil change if I'm lucky enough to get out that much).
Does anyone know what size bolts match the bellhousing to the block? Also how many if possible. Another bolt question. I'm thinking the bolts that hold the brackets to the block/heads are the post's with the bolt welded about 1/3 of the way down, which way do these insert? I hate to even ask these questions, but I've never torn an engine down and although I thought I was being careful I guess there was some degree of haphazardness.
Thanks for any info anyone can give.
Sean
Sean
