Everyone should read this about sea foam
greasemonkeyozi
I have found another addition to my checklist in preventive maintainence to my motor thanx to this web site. I was told about something called Sea Foam. This stuff is more like a tune up in a can. <br /> I took out my spark plugs and sprayed a good bit in each cylinder, let set over night, and started motor next morning. Man, that stuff blew out all kinds of junk out the exaust. I then sprayed some in my carbs while motor was running and let it clean my system out. I had then took her out on the lake and she started without choke. I couldnt believe it. Then she came out of the water like there was no tommorrow. This is some good stuff.<br /> I also used it on my weedeater and even she starts easier, and runs smoother. It did take a few pulls until she would fire up, now all it takes is one.<br /> I dont know what this stuff is, but I highly recomend it for all motors. I was told to use 1/2 can every 3 tanks of fuel.<br /> Does anyone have any better advise on how to use this stuff, or any advise on other products to use on these motors? What about a good additive in the lower unit lubricant?
D
DJ
Guest
Re: Everyone should read this about sea foam
Been using it for years. Add a little to every fuel fill up. Keeps the rings free.<br /><br />Glad it worked out for you.
skier
I put Amsoil lube in the lower unit and gained another 150 RPM's<br /><br />Craig
Kenny Bush
Yepp........ I put a can in every 3rd fillup. Keeps my motors clean. I also use it in all my fleet of internal combustion motors and I swear by it. I am however, getting tired of being a salesman for this stuff.... SeaFoam should give me free product, because I know I have sold tons for them.... :D :) :cool: :p
tmac58star
Bushcat,<br />Where in Tejas can you get in bulk, like tasty beverages...for not too much scratch?? online??
JB
Moving to General Outboard
