Ever tried this????
jcreech1
I have an 81 Evinrude 150 that does not have the speedo hole drilled into the foot. Anyone ever drilled the foot and tapped a fitting in to feed the speedo from the foot? How hard is it? What size bit and fitting should I use. I am thinking it would be very accurate when compared to my external speedo tube.
Re: Ever tried this????
I wouldnt try it, you would be drilling into the shift cavity, causing an oil leak and probably wiping out the gears, (big $$) those speedo holes are machined into the foot.
jhreed
-------------------------------------------------Jcreech, hope this reaches you ok, Do you know of a Lorne Creech of Wachula Florida circa 1955? I was in the USAF with "Bud" for four years and miss him. My email address is jhreed@epix.net if you would like to respond that way. Thanks, <br />Jim Reed.
