Evenrude sluggish
CATDADDY
I have a 1995 40hp Evenrude M# E40EEOD<br />I have replaced power pack,coils,fuel line from tank to motor,plugs,and gapped at 0.30. checked all fuel lines from fuel pump to carb's. checked fuel filter at pump. Motor starts and idles like<br />new. Oh yea I adjusted the carbs. When you give throttle the motor starves for gas. I can hold choke in and motor will pick up.When first put in it may run fine at wot for 3-4 moments then will starve for gas. Using plugs-champion QL78C@0.030in. Allso cleand fuel tank.
seahorse5
Re: Evenrude sluggish
If you have to hold the "choke" in to make it accelerate, then you have carbs that are restricted internally, most likely from stale fuel deposits. This is assuming that compression is good and that the all the linkage is adjusted and operational.
CATDADDY
Thank's for the advice I will pull and clean the carb's
CATDADDY
Cleaned the carbs engine now run's like a raped ape. Thanks for all your help. (happy Daddy}
