stoneagent
- May 15, 2008
- 6
I am re-doing a pontoon boat. I thought I marked all the wiring but missed two. This is a 70 HP engine.
First off I have a large wiring harness bundle coming out of the bottom of Controls that goes to the engine.
There is a small harness coming out of the bottom of the controls with purple gray and blace that goes to the tach.
There is a separate set of wires that are not bundled but are taped together that are red green and blue. Each of these has a white tracer. Along with these are the tan and black with a white tracer. (Which are my problem wires.) These five wires go to the engine and terminate in a plug. The red, green and blue go off to the top of engine somewhere. The black goes to the engle ground and the tan goes into another plug that become a white with tan tracer that goes down to the lower unit to some relay or switch. Don't know what it does.
Back at the captains console the black and tan wires have a screw connector end. So I figured they go to an instrament or they could go to the controls. I lookerd at the switch and all the terminals are dark as if some coating was put on them. The tan and black terminals do not have the same coating..I figured they didn't go to the key switch or on the shifter because of that. Do they go to the guages?
The tach zeros out when you key turned on and I hear the solenoid engage with key on and push to choke.
The motor is a 70 HP I do not know age. I looked for serial number on port side mounting bracket but could not find. Is it on the mounting bracket attached to boat? Or on part the raises and lowers and swivels?
I did get the engine to turn over now.
Thanks for your help.
Dennis
Dennis
