Evaluating Alpha 1 condition - pics
stunt822
Hellow to all dear gurus!
Looking for opinions on condition of outdrive i have, based on pictures of oil and magnet.
Now, in ideal world ofcourse it would be great to rebuild as soon as anything is wrong. But in that same world - i wouldn't be owning a 16 year old Capri:) :)
So, I have a 1999 Mercruiser 3.0 with Alpha 1, have put 30 hours on it past summer, after oil change. ALl hours - wakeboarding, so lots of starts.
And this is what I found when changing oil.
1 - Some shavings, nohing feels to fingers, all very thin. Is amount reasonable for 30 hours of wakeboaring use?
http://i1195.photobucket.com/albums/aa390/stunt822/Boat/magnet_zpsd0ky1lxj.jpg
http://i1195.photobucket.com/albums/aa390/stunt822/Boat/shavings_zpsuypvnzcb.jpg
2 - Definite water presense in oil - white-ish streaks in oil as I drain, from start to empty. ALso some white residue on the bottom of oil reservour in engine compartment. on scale of 1 to 10 of badness - how bad is this?
I was not planning on rebuild just yet.
http://i1195.photobucket.com/albums/aa390/stunt822/Boat/oil_zpsvwduqkdp.jpg
Thanks!
sharkin95
pressure test outdrive .....if oil is found in the driveshaft bellows upper seals are gone..... milky oil in outdrive water pump seals are gone. go to adults only section #13 to test outdrive
Thanks!
Ayuh,.... Welcome Aboard,.... Is this a trailer boat, or dock boat,..??
Any visible oil weepin'/ leakin',..??
That fur don't look to bad, 'n the streaks/ sludge is probably condensation,....
Watermann
I'm not a guru but Iv'e walked the walk.
1. Until there's an actual problem, run it.
2. That's nice and green gear lube, not a milkshake. Let that container sit and see what separates.
