European 9.8 hp Blueband 110 with s.n. 902..... - which plugs?
Gollis
The engine:
Mercury 110 9.8 hp (? - that's what it says on the cowling), probably bought in Norway, with s.n. 90249**
Cowling looks like the Bluebands, has "Thunderbolt Ignition" written on it. Propeller has two blades.
Spark plug wires also have "Thunderbolt ignition" written on them.
There is a sticker on the power head reading "Kiekhaefer perma gap"
On the carb, I can read "Mercury" or something similar.
I aquired this engine one month ago, and I have used it for about 20 hours - just to see that it actually was working. Then I proceeded to cleaning up the cooling system (the indicator stream was very weak before I flushed thoroughly, in every direction, using a water hose and a vacuum cleaner), "changing" gear oil (salt water came out) and ... spark plugs. After having spent hours on finding what I thought were the correct spark plugs for this model, I bought and inserted a pair of NGK BUHW-2 (without side electrode) , only to find out that the engine only fired on one cylinder - the other cylinder worked very rarely and only at the highest rpms.
I originally wanted to change the plugs because the engine was difficult to start, requiring start gas every time. With the new plugs, the engine started quickly.
I re-inserted the old plugs, Champion L77 JC4, and with a warm motor, the upper cylinder works most of the time, but only on higher rpms, something that I didn't notice during the previous 20 hours I had the engine running. It was apparently working properly before my rather brutal attempt at flushing it.
I am suspecting either compression loss in the upper cylinder, or that both of these plugs are the wrong ones. I have not tried with a new pair of L77 JC4, because I cannot find any reference to it in Mercury manuals from the suspected production dates (1971 - 1976) Knowing the production year or the equivalent, American model would be a great help.
Could someone suggest what plugs I should use, or attempt to explain what I am experiencing?
Gollis
Re: European 9.8 hp Blueband 110 with s.n. 902..... - which plugs?
Hopefully, I have given sufficient information.
Anyone .... please?
maxum247
Ok! I'm going to give this a go.
maxum247
Mercury repair manual, Sparkplug L77J4 gapped at 0.040 which I think the L77JC4 is it's replacement but not certain. When you flushed your engine things could have gotten wet in which case it can take longer than you think for things to dry out causing the engine to run poorly where it didn't before.
Compression gauge will give you a decent idea of the condition of the engine. I think I paid less than $30 for the one I have. Cylinders should ideally measure within 10 pounds of each other.
Hope this helps!
max!
