DavidInWilmNC
- Jul 20, 2009
- 50
I just installed a new Racor water separating filter last week. I'm using portable 6 gallon cans until I get the internal tank replaced. I'm also using all new hoses, and the carbs were rebuilt early this summer. Saturday, I drained both tanks and filled them with fresh gasoline from the station. Sunday, I took the boat out (with a '96 Johnson 90). It ran much better - smoother, little surging, didn't stall, etc - than it did last time. Before taking the boat out, I ran it in the driveway for about 10 minutes or so. There was a noticable amount of water in the clear part of the filter. I wonder if the station has contaminated gas. It's an 'off-brand' station, so I'll try a BP / Amoco next time. When we had it oun the water, it ran well, but wouldn't rev over 4000. It didn't seem to have as much power, either.
I know ethanol has a greater affinity for water than it does for gasoline. What happens to this ethanol when it goes through the water separating filter? Is the ethanol filtered out with the water or does it pass through the filter with the gasoline? If so, I'm wondering if I'm actually seeing a higher concentration of ethanol in the gas than I would normally. I know ethanol has less 'power' than gas, so I'm wondering if this could be the cause of my motor's sluggish performance / reduced power.
