scottfromoz
- Jan 1, 2006
- 90
Hi all. I have a 93 Yammy 115 V4 2 stroke that hasnt ever missed a beat. One day though I might go for a power upgrade to 175 or 200. If I do I would consider a new tech motor - and I like the principle of the ETEC. My question though is whether they are really going to be a nightmare out of warranty with 1500 odd psi injection pressures and extra lean burn... Its like modern Turbo Diesel motors in Four Wheel Drives (SUV over with you fellas) - incredibly high injection pressures and where injectors with built in pump and piezzo injection set up costs a bomb ($1500 Aud or so EACH injector).
I know that, realistically, a modern motor with the gear referred to above, computer mapping (as opposed to a relatively simply HEI ignition system such as that on my Yammy) and sensor's etc must mean that it will be more expensive to run, parts wise (I dont do that many hours per year to talk fuel savings) and labour wise (whenever you have sensors your talking parts of a volt in feedback so even a slightly corroded earth can cause nagging problems to find) than an older tech motor, but how much worse would it be?
I would appreciate answers from either actual experience of these motors, or from outboard mechanics or similar rather than speculative answers from ETEC lovers or bashers...
Cheers
Cheers
