Hay guys
I bought a left over Etec 150 - 2007 and I have a problem.
The VRO no oil light comes on after I get it in the water after one use.
Oil ran thought the houses during set up and test start no problem.
I checked the Oil at the connection joint and after the oil filter when primed they both flow good when I hit the primmer bulb.
While all connected I can not prime into oil tubes now and the pump is running dry. No oil getting in
What do I have here? Where do I look?
Note:
I used the older type of Oil tank that I had with a 1997 Oceanrunner, which I was told was the same.
I was also told I do not have an oil return.
Note:
