FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have an 1976 1978C Eska 9.9 lower unit I am attempting to re seal. just below the water pump housing is a white plastic/nylon part. I can't get it out. It will spin but not come out. the seal is just below this I believe. any help please!!!!!!!!!!
theres a small lock ring to remove, kind of hard to see, you need a very small flat screw driver or pick to remove it. you may have to hold one end steady while you pry the other end up.
thanks for the response, however, I do not think there is a lock ring. I assume you mean on the inside circumference of the casting around the plastic piece. I will try to post a picture tomorrow.
Your right as rain, there is no lock ring...my eyes decieved me because I could have sworn I could see a lock ring however on the heals of bad information I awoke early this AM and since I have to re-seal my lower too I decided I would master this beastie...I simply used a small flat head srewdriver to pry and channel locks to turn and out she came...notice there is a O ring around the retainer plate and the seal is on the backside.
and just a little comparison and I see that eskaman has a better price than sears, but you can also get new retainer plate from sears...sears will also charge a minimum of 10$ to ship
thanks, that IS the little monster. only thing is the kit I purchased does not have that o-ring in it. looks like they sent me the wrong one........that never happens
I have had real trouble with sears and Ted Williams parts orders, you have to watch them on seals and such, last order they fouled it so bad they gave me my money back and told me to just keep the parts, but had no intention of changing there part no. even though it was wrong
