FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have just gotten an old 1970eska 7.0 hp outboard model 217.58531 , It starts fine, but I can't seem to find out how to change the oil. can anyone help me out? even if there is someone out there with a manual that can send it to me in pdf format or something, any and all information is greatly appreciated..
While that is an Eska motor it was built for Sears.That is a Sears model number.
Pull both the upper vent plug and lower drain plug,lay motor on its side and allow it to drain.If lube is milky or water is present you should renew seals and gaskets.Stand motor uprioght and fill with outboard gear lube from the bottom plug until it reaches the level of the vent hole.Install vent plug and then the drain plug.
I really appreciate that information. but I have no diagram of the bolts or locations of the bolts you mentioned, I am going to take a good look at the motor and see if i can locate what bolts you are talking about. do I need to pull off the rope starter? or is it something easily done without taking alot of the parts off?
The only oil to change is in the gearcase by the propellor.
The drain plugs are flat slotted screws one (drain/fill) just above the gearcase starboard side near the front the other (vent) is port side higher closer to the rear.No need to mess with the recoil starter as it is at the oposite end.
Have you ever messed with an outboard?
not really, i have messed with 2 stroke motors lots of times, but never on an outboard, i just assumed there was oil in the crankcase of the motor too.. this is a 1st for me. so everything is done down by the prop. ok i can deal with that then easily. And should the motor spit water out the exhaust holes only when not in neutral???
