eska 5hp
dickins
hi
just bought a 5hp eska
model 1705-f serial 3l-657568
motor info t643-19b
tecumseh 7158918 could any one tell what year,and help find a owners manual,tried the sears site these # did not work,i set up in a barrel of water (after checking it over) it started right up, gas came out of a vent hole in the top of the carb,took carb apart and cleaned i need a new casket,
thanks in advance
martin
CATransplant
Re: eska 5hp
Model 1705F is a 1974 model.
For parts, go to certifiedpartscorp.com, then call the number you find there. Have your engine model # and serial number handy. They bought all the parts when Eska went out of business, and have a very good stock.
dickins
Re: eska 5hp
hi
thank you for the reply
any chance you could tell me the fuel oil ratio,the spark plug in the motor is a champion j 4 c ,i dont think this is the right one
thanks in advance
martin
CATransplant
Re: eska 5hp
I don't know the plug number, but you should run that one on 24:1, using air-cooled two-stroke oil, like that used in chainsaws.
steelespike
Re: eska 5hp
My info says 32:1 when using TCW rated oil. The Supertec oil container and my Citgo extra range container say TCW3 may be used in applications in place of TCW oil.Exceeds requirements for TC-W and TC-WII Oil container also says Recomended for 2 cycle engines,including outboards,snowmobiles,motorcycles,chainsaws,string trimmers and lawnmowers.
Recomended Plug is Champion J13Y set at .030.
dickins
Re: eska 5hp
follow up report,found a new plug,made a new gasket,found a few problems in the carb and fixed them,ran motor today ran very well, starts first pull(really)thank you for your help
martin
