I have an older (but in like new condition) Tohatsu 2.5 HP outboard, Model 2.5A. This unit does not have the electronic ignition system, but rather the older points/condenser/coil setup. It has spark.. but when started it only fires on every third or fourth revolution (surges) and eventually quits. I have had the coil checked and it is OK! The spark plug has been replaced. The carburator has been removed and cleaned. The cylinder has excellent compression. All electrical connections have been cleaned but the problem persists. I have owned this engine since it was new and it has always operated flawlessly until this problem developed. Any and all suggestions and or comments that might help me solve this problem would be GREATLY appreciated. Thank you..
