EPIRB Question
valleydawg
I am looking to buy one for my 24 ft boat. We run offshore and this looks like something I should have. Do you just activate by hand in an emergency? What do you guys use? Any recommendations? Thanks
Pez Vela
Re: EPIRB Question
All styles may be activated manually. Manual activation is the only way to activate a personal locator beacon (PLB). Class I and Class II EPIRB's will not activate while in their brackets. After a Class II EPIRB is manually removed from its bracket, it may be manually activated, or it will activate automatically once it is wet. A Class I EPIRB will be automatically released from its bracket after it is submerged a certain depth (something like 3' to 14' deep). Then it will activate because it is wet and float to the surface if it isn't snagged on something or otherwise restrained. If your boat will not sink, the automatic bracket release of Class I EPIRB may never come into play. Compare the other features on PLB's and EPIRB's (especially battery life /transmit times) and get one ... that's the important part.
valleydawg
Re: EPIRB Question
Is there a monthly fee for the service once you buy a EPIRB?
sasto
Re: EPIRB Question
I use two 406 catagory 1 beacons on 2 different boats which are activated manually or automatically. I register them with NOAA every 2 years, unless info for the vessel in which it is mounted on changes.
I would stay away from catagory 2 beacons, they have their problems.
Pez Vela
Re: EPIRB Question
No. Registration is free and the only ongoing expense would be the battery replacement fee at the end of the battery's useful life, typically every 5 years.
Boatist
Re: EPIRB Question
If you go more than 30 miles out to sea then EPIRB is the way to go But 29 miles out your VHF radio will get you help faster as you do not have to wait for a satellite pass.
Coast Guard's Rescue 21 designed to work out to 30 Miles for the entire USA Coast will get help faster from the Coast Guard.
VHF DSC Class D will be the only radio sold in the USA after March 2011.
rodbolt
Re: EPIRB Question
I vote for the EPIRB.
boats rarely sink on calm sunny afternoons.
VHF is strictly a line of sight communication device thats very much affected by mast height above the water and weather conditions.
the EPIRB will alert the USCG and others, as to the lat and long to within 30 ft or so of the transmitter.
its also a microwave transmitter thats not as affected by weather or mast hieght.
most VHF sets rely on the hulls electrical system, one of the first that fails when saltwater hits the battery.
the EPIRB is stand alone and doesnt require operator attention once activated.
typically when a boat starts heading for the bottom there is not a lot of time to discuss it with the USCG.
in my area the gulf stream is 20-30 miles out either from oregon inlet or cape hatteras inlet.
the USCG airbase is in Elizabeth city.
total distance is about 50-80 miles, takes about 30 min from station E city to the gulf stream just to start a search pattern.
takes 10-15 min to get the whirly bird aloft.
get hung up in the diamond shoals area with a good 40kt north east breeze and odds are high your not gonna float for 45 minutes with the boat.
we have done man overboard drills in 25-30 ft seas.
even knowing where the dummy hit the water, oscar is all dressed in orange, its almost impossible to keep a line of sight on the dummy.
30 miles out there are no land marks.
thats why we toss smoke at the first call out of man overboard and try to keep a visual.
valleydawg
Re: EPIRB Question
Guys - I am thinking about buying the Fast Find (PLB) due to price. $250 dollars where the EPIRB's are $500 dollars. Anyone heard anything good or bad about this unit? Any other comments? Plan to purchase in two weeks. Thanks
LippCJ7
Re: EPIRB Question
Good info guys keep it up and don't be shy about it!! I never knew any of this stuff even though it doesn't apply to me its nice to know!
