Enough power?
whfmznb
I have found a geat deal on a 2003 Johnson, 15hp, 4 stroke, for my 14' SeaNymph aluminum boat. I'm a big guy, 300 or so, and am concerned about whether or not it will get the boat up out of the water. I have a 4hp 2 stroke now, so I have very little to compare it with. I'm no speed deamon, so that's not an issue. ant thoughts out there?<br /><br />Thanks
NathanY
Re: Enough power?
How heavy is the boat? How heavy is the gear?<br /><br />If it is average, I would say that it would be plenty of power for you. I had a 15hp Seaking that would plane my 14ft aluminum boat and I weigh 270.
whfmznb
Re: Enough power?
The boat weighs 245lbs, gear consist of tackle box , battery, trolling motor....
BR549
Re: Enough power?
You will be fine - I am around 270 pounds and I spent 10 years or so tooling around in a 14 foot flatbottom with an 8 hp Merc. This would top out at around 16 mph in ideal conditions if I turned my hat around backwards. You will just need to spend a little time figuring out the optimum weight distribution for gas tank & battery.
whfmznb
Re: Enough power?
Thanks to all...I have another question but I will add a new post.<br /><br />Thanks again
