Enough for this Impeller? Pics Inside
  • Total voters
    41
krakatoa
Guys!
I have changed the impeller last week from my OB, waht do you think, its enough for this guy or can handle a little more? :D
images has beenn deleted!
joed
Re: Enough for this Impeller? Pics Inside
It looks like the one I changed last year that worked fine at high speed but would overheat the engine at idle.
I say it's done.
badkins50
you can never go wrong with the better safe than sorry outlook. good call.
MAXXIE
As long as it's apart, why not? It is a cheap part that can, if it fails, destroy the entire engine. I doubt too many would disagree. I don't know what size or type of motor it's from, but mine was only $24.99 for the impeller itself. Can't go wrong & at least you'll have piece of mind knowing you have a new one in there.
Wingedwheel
If its permanantly curved like that then the rubber is hard. Its time to replace.
eli_lilly
If one fin snaps off and gets stuck in the cooling passage you'll wish you'd have replaced it.
-E
krakatoa
its came of from a 1993 Mariner 115 HP. I own it over 2 years ago, also the t-stat has been changed, now the OB start to "pee" in 18 seconds, before have to wait over 5 mnts or pull the choke. Never has a trouble with temp. Thanks god!
NYBo
Hard to say without seeing how it fits in the waterpump housing and how well the vanes flex, so I said "Maybe".;)
Jeep Man
The old impeller is in your hand. You said you changed it out. Why are you asking THIS question? The question should be...What do I have to do with this impeller to make it an effective doorstop?
Rudi2
Good answer ;-). I've always gone with the school of thought that says if you go to the trouble of taking it out - replace it.
79Merc80
How about this one I saw last week?
rodbolt
that one most likly melted the water pocket in the upper as well, always fun when those bolts break.
Boss Hawg
Thanks- saved me typing the same thing :rolleyes:
If we ever have a poll on "The silliest question asked on a poll" I vote this'un :p
Haffiman
An impeller is 'gone' the moment its wings do not flex back to 'straight' when removed from the housing.
paultjohnson
When my engine started to run warm, I replaced what APPEARED to be a perfectly good impeller with a new one. Overheat problem gone.
If in doubt -change it out. Especially on those inexpensive [relatively] maintenance parts. :p
sethjon
Guys!
Thats about as bad as it can get without breaking a blade.
Brewman61
Ensign
I don't inspect my impeller, it just gets replaced whenever I pull the outdrive and crack it open. False economy in my mind, to open the water pump check it, and put it all back together again. Glad they're inexpensive.
