I have a 85hp mercury '76 model. I recently replaced the water pump on the lower unit. when placing back together the shift from foward to neutral to reverse was reversed. I have taken back apart several times to move the shift shaft ,but when together. I either get every thing reversed or stuck in foward only. cables have not been touched to be reversed nor has the shift lever housing
