engine
davegolf
has anybody any comments I want to buy a <br />mercury 15hp 4 cycle outboard but I have run<br />into a big problem. it is going to be put on<br />a 12 ft boat but because of the weight I have to shift my weight forward so I need a <br />extension tiller handle no problem, but the <br />kill switch is on the end of the tiller handle.and mercury has no way to change the switch from there. Any help would be appreacated thanks. <br /><br />------------------
corm
Re: engine
Hi Dave,<br />Buy a older year kill switch that mounts in the side of the cowl with a lanyard or a aftermarket kill switch and mount it where you sit or on the handle. Sounds like you need a 14 boat.<br /><br />...have fun...corm
davegolf
Re: engine
thanks corm but I have just found an <br />extension handle with a hole in the bottom that allows access to the kill switch <br />thanks for your reply dave
