Re: Engine Year??
Post the model and serial numbers...<br /><br />Please do so using this same thread. It makes life much easier that way.<br /><br />Normally there's a engine I.D. plate riveted to the transom bracket. You should find the model and serial numbers stamped there. If not, then look at the soft plugs on the engine block. Serial numbers are often stamped there as well.<br /><br />Walt
