I have twin Honda 90 HP. The problem I am having is that one of my motors won't turn over. I jumped the battery from the other engine and it starts. When I remove the jumper cable the engine dies. I have installed a new battery, cleaned all terminal and connectors, checked all fuses and all were in good condition. There is power going to my ignition switch and to the starter. I even swapped the harness and still it doesn't start. Is there something I over looked? I have a hunch that it is grounding out somewhere. Could it be the rectifier or starter? I don't think it is a computer problem. Then, I tried jumping it again and this time it doesn't start. BTW I also check the neutral switch and it is good. So basically I have power going into the motor but it doesn't turn over. I also checked with the local Honda dealers and they are stumped as well.
