Mr. Moderator. I did post this same question in the "Props" section of this forum Please don't be too angry with me.
I have a 2003 Johnson 90 (Bombardier) V-4 mounted to a 17 ft McKee Craft CC Boat. 20 Gallon gas tank mounted under console. Motor runs great, idles great....no issues at all.
However,
To get the motor to run in the 5500-5800 RPM range, I can only turn a 14 x 13 pitch prop. Everyone says I should be turning a 14 x 17 minimum, so there must be something wrong with my motor. I did a compression test and it is very close to 125lbs in every cylinder. Is there something wrong?
Oh, I forgot to mention. Motor is mounted in the third hole up, and the cavitation plate is about 1/2" above the bottom of the hull.
However,
