Sjones2105
- Apr 27, 2017
- 5
Hey everyone! I'm so I have a Mercruiser 7.4l bravo 3.
She. I turn the motor over it cranks slow. Here's what I have done.
1. Checked batterys charged and Checked voltage. 13.5 is almost perfect and that's what they were at.
2 Checked all connections to make sure they are clean that's from the battery 2 the starter. The starter connection has a little rust but nothing that shjould cause trouble.
3 Pulled plugs and rotated the to make sure there was no water in any cynders.
So far everyrhji g looks normal. So I'm the no g about pullin g the starter... having it tested ? I have had starters lock up but never had one just not turn fast Enough to not start is this a possibility? Also could there be a bad ground somewhere that I didn't check That would cause this? Thanks for the help!
