engine wont start 1994 sea ray-rayder
redsoxs1969
I have a 1994 sea ray-rayder jet boat went to start engine wont start. Wants to turn over but wont. Looks like no spark
Don S
Re: engine wont start 1994 sea ray-rayder
My guess is you have an outboard powerhead on a jet pump, so you would probably have better luck posting your problem in the appropriate outboard forum. Also post exactly what engine you actually have,
spartanpele
Won't start: Heres a couple of things that could be wrong that could be the culprit...but can't help more without more details on the engine make/model, etc.
electrical-poor connections, low battery, bad spark plugs, bad starter, bad solenoid, bad neutral switch, bad laynard switch, etc. *Get yourself an owners manual and a multimeter and start the hunting.
fuel-no gas, bad fuel pump, clogged fuel filter, water in the fuel, timing off, carb has problems, etc..
*Again, get yourself an owners manual and start the hunting.
Could be any of these things or a combination....need more detail on the setup and history.
