Hello All, I'm newish to the forum and I have a question about an idling issue on my 4.3l mercruiser V6 with a Mercarb 2bbl carburetor. A little background... boaught the boat 4 years ago used and it ran fine, no issues, since then I replaced 2 exhaust manifolds, fuel pump, carb, electrical. I got the carb 2 seasons ago at the end of the season, ran it once last year and it ran great!! Took it out last month and had an issue with it stalling below 2000 RPMs. I figured there was gunk in it so I cleaned the carb the best that I could without taking it apart and rebuilding it (used 2 cans of Berrymans). Still sounds like it's starving for fuel. Haven't touched the idle screw yet to adjust the leaness of the fuel. Replacing the fuel line from the carb to the fuel pump (it had a fuel leak and found it was cracked) haven't really touched the throttle screw on the side yet only to get to 2000 RPMs... besides a year down and rebuild of the carb... anything else I can consider looking at? I'll post a pic of the carb tomorrow if you guys need it. Thanks for all the help I greatly appreciate it
