Re: Engine wont idle
Hi coggin,
Try removing your jets screws and spray some cleaner in the jets. Be sure to set the jets at the correct specs. I am not sure what the specs are for that motor but hopefully you have a manual that will help you. May also be fuel pump diaphragm. Good luck.
