Bama Hound
- Jul 30, 2012
- 47
Engine won't go past idle in gear on a cv-4 90* 1993 J115TLET
I have built carbs, replaced water pump impeller, replaced starter and solenoid thermostats and relief valves and regulator rectifier. I have timed WOT-4* which is 24 BTC I have set idle timing to 4* BTiC. It will start idle good (kind of) idles at 1100. Drop in forward and idles at 950 on trailer in the lake. If you try to advance throttle it will croak. I have had this boat 3 years but didn't run it last year cause health problems. The way I am reading things I should be able to pump bulb until firm. This has never been the case. I would pump it 10 or 12 times and if I went out within the next 3 days I wouldn't even bother to pump and it would start and run fine. I have a VRO changeover. Boat has built in tank. Hose and bulb are new. Anybody want to venture a guess here. I did a compression test on cold cylinders (because it wasn't running at the time) numbers were from 95 to 105 shot Marvel Mystery Oil out of squirt can in just prior to test. Have to admit here while setting WOT timing only tested spark on #1. Which I could hear but couldn't see in bright sun, I have to do timing at dusk even to be able to see timing light, and mosquitoes size of Hummingbirds are only helpers. I am kind of lost here and my "sea time" is drawing to a close. Live on a lake that drops 5ft.sea level starting Sept. 28, so any good guesses are more than welcome. P.S. redid link and sync after carb removal as well as WOT stop. I am remembering now that if I put boat on ramp and tried to power up to keep from drifting off it would die after a full power push is this normal or has it had some ongoing problem?
