Engine will not shut off with key
robsm78
I have a 2002 Tohatsu 50M outboard engine. It will not shut off with the key or the kill switch (safety switch). Also my trim guage and rpm Guage stopped working. I had to unplug the fuel line from fuel tank to shut engine off.
pvanv
What is your actual model? Sounds like the RC box is disconnected.
pvanv
Verify brown and black grounding wires and confirm RC cable is connected properly.
robsm78
Cannot find any problems with wiring or key switch, so far. Thought I knew how to trace and test theirs but guess I'm just shooting in the dark at this point.
pvanv
The stop function grounds the brown wire. Is that working?
ahicks
We'd both like to help, but you aren't giving us much to go on.
For your testing, are you using a volt meter, a test light, what?
Is your testing being done on the back side of the ign. switch, or somewhere else?
Is there anything that does work?
