Engine turns over but won’t start
Chuck SC
2003 SeaRay 5.0 Mercruiser starts cold with no problem. Runs fine for hours but when you turn it off it won’t crank again. Motor turns over but no start. Moving handle 1/4 inch forward to start doesn’t work. Replaced IAC with a Mercruiser part but that apparently is not the fix. Advice???
TunaFish389
Air, fuel, spark. Could be any of these or a combo. How long while not running does no start show. Shut down then right away no start, shut down then a minute no start or five minutes?
Chuck SC
Runs for as long as you don’t turn it off. . Shut it down then it’s about 30 min for it’ll start.
San_Diego_SeaRay
Like Tunafish eluded to, running a motor only requires three things: Compression, fuel, and spark (although he said air).
Compression is generally never suspected when an engine will run before and after an intermittent problem (in fact compression is generally the least likely suspect of the three).
So from a mechanic's perspective, you're left with two suspects: Fuel and spark. Years ago when I was a backyard mechanic, we would spray Starting Fluid into the carb to eliminate spark as a suspect. If it starts after spraying, then you know you have a fuel problem. It will only run for a few seconds...but tells you what you need to know. Not sure how people feel about using Starting Fluid on this forum...
EDIT: Here's a video of what I'm talking about. But always keep in mind that starting fluid is extremely flammable. You should always assume the worst when using it; ie that there will be a backfire, etc. Keep a damp towel on hand to smother a fire and, as a last resort, a fire extinguisher.
89sandman
As posted above I'd hit it with a shot of starting fluid and see what happens. Quickest way to eliminate fuel or spark. My guess would be ignition module, which is pretty easy to test. Hook a volt meter up to the coil wiring and see if it "strobes" while you are cranking it when it won't start. If not that the coil itself would be my second guess.
