I just bought an 85 Sea Ray with a 170hp Mercruiser 4-cylinder. The boat has been sitting for several years when I got it; I'm now trying to get it started. The starter cranks and the engine turns but it does not start because I'm not getting sparks out of the plugs. The distributor looks almost new, so I'm focusing on the coil.<br /><br />When I connect my multimeter between each terminal on the coil and ground (engine case) I get 12V. So 12V between the positive term and ground, between the neg term and ground, and even between the center node (that connects to the distributor) and ground. This is while the key turned to ON, but not yet on Start. I don't measure anything between the two terminals though, even when starting. I hooked up a light probe across the two terminals and saw no light when I'm starting.<br /><br />I'm thinking I should get 12V between the two nodes, but I'm not. Can I conclude that the coil is bad? Any ideas what's causing the lack of spark?<br /><br />By the way, when I say I'm getting 12V, I really get only 11.x or 10.9x. Is this normal?<br /><br />Thanks in advance for any help.
