Engine trouble
lbelth
I have a 2006 Bayliner 175 that won't go top speed when the throttle is wide open
Silvertip
Ummm, what motor, EFI, Carbureted, what HP? Did you just get this boat? Has it ever run as it should? Was any work done on it recently? Did it run fine before the work was done. Details -- details - details!
welcome aboard
is your motor an outboard or an I/O?
if an I/O it would have a 3.0
what RPM are you seeing?
what speed are you seeing? (verified with GPS?)
new to you boat or new issue with old boat?
